Blower motor location
Old Dec 28, 2022 | 08:24 AM
Thatch's Avatar
Default Blower motor location
I have not been able to find information on the exact location of the blower motor on a 1983 xj6.
Could someone point me in the right direction?
I'd like to put power directly to the motor to see if it works.
When I turn the switch I can hear relays and a it seems like it's trying to work but no fan operation at all.
I've checked the fuse and replaced it under the driver side dash.
Old Dec 28, 2022 | 02:05 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
An easier way to see if the fans work is remove the left forward console panel that is held by the two screws holding the black plastic heater vent. Use this picture to locate the relays mentioned below. Muttony, who is one of the members, wrote a very detailed and useful post (link below) on trouble-shooting HVAC problems.
https://www.jaguarforums.com/forum/x...ations-216854/
"The point of all this is that there should be 12V battery power at the relay regardless of key position at post 30/51 which is the post in the middle with the screw and the Brown and White Wire. As seen on the diagram, power goes from post 2H via a Green and Slate wire directly to the fans.
Verifying the fans function is simply a matter of jumping the Brown & White to the Green & Slate. If the fans come on, then the fault is elsewhere. In my case, doing this caused the fans to come on so Gummed Up fans was ruled out."
Dave
Old Dec 29, 2022 | 09:46 AM
Jose's Avatar
there are two blower fans, each enclosed in a blower case, one driver side, one passenger side.
There is a green wire and black wire marine connector on each side entering the blower cases corners near the kick panels.
Disconnect these connectors and using a spare battery with two wires, positive pole to green wire, negative to black wire, you can test each blower.
otherwise the problem might he the large relay explained by Dave above.
craigisakson
Oct 19, 2019 12:20 PM
jcuba53
Jun 7, 2015 09:34 PM
pan84
Sep 16, 2011 12:50 PM
ilovetrains
Aug 25, 2008 03:19 PM
