Brake resevoir cap assembly
Old Jun 4, 2016 | 08:06 PM
smith356's Avatar
Default Brake resevoir cap assembly
Today, installing new plugs, I broke one of the rubber hoses to the master cylinder. Having only driven the car around the block couple of times in the last 18 months, it never occurred to me to open the reservoir and look inside - OMG, what a crystalized slurry ! There is a cylinder under the cap that has been eaten up and I need to replace it. Can anyone help me with a diagram and part numbers ? (this is my 73 xj6). I think I'll be replacing brake lines, too - scary stuff !! I did see, on ebay, an OEM cap assy #C45055, but couldn't determine if it's correct yr or what's in the package. Thanks much, Jim
Old Jun 4, 2016 | 08:36 PM
o1xjr's Avatar
I'm pretty sure there are two different resivoirs available for the series 1.(depending on your cars serial number). If your car is a series 2 it may be different again. I think from memory I may have sent you some series 1 parts,or looked into it at least.
I will get my wife to take some pics of the parts book and email them to me.
Will post pics later today.
Old Jun 4, 2016 | 10:13 PM
o1xjr's Avatar
Old Jun 5, 2016 | 01:34 AM
smith356's Avatar
That's Perfect ! The part# C33116, in the first diagram, is what I need. Thank you for your kindness in getting this on the forum ! Now, if anyone has one available, I'm on the hunt !!
Jim
Old Jun 6, 2016 | 11:21 PM
smith356's Avatar
Default you're Spot On !
You have sent parts to me, and I thank you again for that ! Have I told you this already - I took 2 R&Rs in Australia while in Vietnam - Loved it there !
I was there on my 21st birthday and retain wonderful memories of both trips.
Thanks again for the diagrams !
Old Jun 7, 2016 | 06:51 AM
davidboger's Avatar
I think that part number was superseded a few times along the way..
I have CAC4578 which should be the same part.
I don't have the cap for it, but do have the housing and filter as New Old Stock.
Perfectly solid, new assembly..
Here:
Jaguar XJ6 XJ12 XJS Brake Fluid Reservoir CAC4578
Thanks!
David
shop.everydayxj.com
Old Jun 7, 2016 | 07:40 AM
o1xjr's Avatar
I had trouble locating a cap for mine,eventually found one when I went to buy tail light lenses from a local add. The guy had one sitting on his workbench.
This is the only cap I found tonight in a 1/2 hour search, but it comes with the complete resevoir.
Jaguar Brake Master Cylinder Reservoir XJ SI SII XJS | eBay
LnrB
Feb 27, 2017 02:48 PM
BobRoy
49
Sep 18, 2016 10:48 AM
jetjack
Apr 11, 2016 02:46 AM
scottpeterd
Apr 4, 2016 10:48 PM
JagSTR2004
Mar 31, 2016 08:22 AM
