A/c Amplifier
Old Jan 9, 2020 | 06:56 PM
  #61
Bearing1's Avatar
Default AC amp.
Yes I still am doing them and still 200.00 shipped within the USA, overseas shipping is extra whatever it costs me passed on to you.
Old Jan 10, 2020 | 10:42 AM
  #62
I got a New Amp from Jag-Aire, October 2018. Cured my problem!
www.Jag-Aire.com.
He makes them according to original specs but with modern components.
Gary posts in here sometimes, good fella to do business with. Check him out.
Old Feb 2, 2020 | 03:27 PM
  #63
ebbnflow00's Avatar
Hey Bearing1. I just got myself an 87 xj6 with a dead ac amplifier. System is stuck on cold. I can manually switch to heat by powering the servo motor directly. When I plug the AC amplifier in, it switches back to cold no matter where the temp is set. Temperature adjustment pot and servo feedback pot check out ok. Temp feedback reads 17k with ambient around ,55f. Pretty sure it's the amp. Thanks for taking the time to reverse engineer one of these!!! How do I order one from you?
Old Feb 13, 2020 | 03:34 PM
  #64
ebbnflow00's Avatar
I want to follow up on this thread to let others know that Bearing1 is a stand up guy. I paid him for an AC amplifier and had it in my hands 3 days later. It's been installed for about a week and my delenaire system is back in action. Thanks Bearing1. You provide a great service to this niche community.
Old May 9, 2020 | 09:55 PM
  #65
Deanfitz27's Avatar
how can I purchase one?
Old May 10, 2020 | 07:08 AM
  #66
Bearing1's Avatar
Just email me at Bearing1@gmail.com
I will get you one on the way ASAP
If you are in the USA shipping is included
If outside USA $200.00 + shipping at cost
Old May 10, 2020 | 07:11 AM
  #67
Deanfitz27's Avatar
I'm in Canada , so it should be no issue. I realize shipping will be extra. Do you have a pic of your amp?. I assume it works the same? Is yourS similar to jag aire? Tks
Old May 27, 2020 | 12:06 PM
  #68
Deanfitz27's Avatar
Default Stuck in AC
Wondering if anyone could lead me in the correct direction. I have a 86 xj 6 which the climate control is stuck in AC. I have tried the water value, with no luck. I also just replaced the amplifier with a new one, still no luck. Where I turn the temperature knob back and forth from 65 to 85 I dont hear servos moving. Is there possibly a fuse to look for? Are the temp switches them self known to fail? Thanks for any help
Old May 27, 2020 | 12:20 PM
  #69
Yellow series3's Avatar
Well, I hate to say it but your servo could be bad. Could be other things but the amplifier tells the servo to move. Take off the cheek panel on the side opposite from the amplifier, that's where the servo is. With the panel off you can hear it better and you should see the little levers move when you turn the temp knob from high to low and back. Keep in mind it is electromechanical and it has a slight lag time from when you turn the knob. Engine running, of course.
Jeff
Old May 27, 2020 | 12:25 PM
  #70
Doug's Avatar
The system has four fuses, actually.
One on the ground wire to the amplifier
One on the brown/yellow wires, clipped to the side of the main HVAC case, behind the console RH cheek panel
Two in the RH fuse panel...although I can't remember exactly which two at the moment
Old May 27, 2020 | 12:29 PM
  #71
Jose's Avatar
yes there is a hidden fuse for the Servo. Located above and to the rear of the servo, near the firewall, passenger side in LEFT HAND DRIVE cars.
remove the black plastic floor vent screws and then pull the panel.towards the engine.
The fuse is in its own fuseholder.
Old May 27, 2020 | 12:38 PM
  #72
Deanfitz27's Avatar
Jeff
I just hajudge car running with the cover off, no servo action
Old May 27, 2020 | 12:52 PM
  #73
Deanfitz27's Avatar
I just checked my fuses, all appear good. Is there any way to check the servo or power it up? Is it hard to take out?
Old May 28, 2020 | 02:22 AM
  #74
Greg in France's Avatar
Go to JagAire's website, they have clear instructions about how to test the servo, and can supply rebuilt ones if needed.
bdboyle
Sep 16, 2019 05:58 PM
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
42Ajd
Sep 26, 2015 07:04 PM
