Cam oil feed banjo bolt sadness
Old Aug 20, 2021 | 02:08 PM
worzella's Avatar
Default Cam oil feed banjo bolt sadness
I am replacing seals on cam oil feed banjo bolts and decided to just "upgrade" to longer bolts just in case my threads were bodged.
Got new bolts in about 3/4 way with plenty of lube, two turns fwd, one turn back. But at 3/4 they were NOT going any further.
Going to bail and use original length bolts. Lots of posts say there is plenty of thread in the head to use long bolts...I cannot concur on my '86
Randy
Old Aug 20, 2021 | 10:18 PM
Randy,
I have not used longer banjo bolts on any 6cyl engine, and had no issues, lucky? doubt it,.
The real engine, YES, always, those tappet block threads are fickle if you look sideways at them.
I was always taught with banjo bolts and copper washers, "just firm", and that is always open to interpretation.
Carby banjo's were the major PITA back in the '60's.
worzella
Aug 7, 2021 10:06 AM
OUScooby
Dec 8, 2018 01:06 PM
JagTheRipper
Jun 22, 2017 06:07 PM
vmaxnick
Jun 2, 2017 02:01 PM
jaghag00
Jan 14, 2017 09:28 PM
