Central flap broke
Hello, the flap of the central grill moves, it came out of its seat, I tried to put it back from the front but I can't. Is there a way to access it more easily? thank you
Ok, the a/c vent in the dash. You can push the flap in with your fingers or turn on the engine and set the a/c at maximum cool and the vent should open. I would guess you should be able to then push it over with you fingers. If that doesn't work you may have to take the vynil pad off the top of the dash. Remove the two small end caps, then there are four screws under the front lip. With that off you'll be able to get back behind there. Hope this helps.
Torque59
XJ40 ( XJ81 )
Apr 27, 2014 10:56 PM
