Common oil leaks
Old Sep 8, 2017 | 06:03 PM
Doug's Avatar
Originally Posted by Dutch-Cat
Maybe it would be wise to drill a hole in the lowest area of the oil pan and thread that, so a drain plug can be inserted later on?
Installing a drain plug is common but decide *where* to drill the hole after the pan is off
Old Sep 8, 2017 | 06:16 PM
jagent's Avatar
Originally Posted by JagCad
My lumped Jaguar does not leak!!!!
Carl
Neither does my 4.2 XK!
Unfortunately, it's my locally built Ford that has mild incontinence...
Old Sep 9, 2017 | 08:28 AM
JagCad's Avatar
Clarke:
1. OK, but, the slick 4.2 car was just rejuvenated. Nice and fresh! Whilst the 5.7 in my Jaguar dates back to 1994. Original as far as I can tell.
2. My son's SOL has a "little" Ford of some type. At 150+ miles, it's beginning to fall apart electricaly. Just got a Transmission Control Module to fix a "fussy crank" issue??? Oh, plus crank position sensors,
cam position sensors and more....
In the meanwhile his big 94 Dodge Cummins powered 3/4 4x4 rattles on at circa 300 K!!!
Carl
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
