Constant ticking from under the hood
Old Jan 21, 2015 | 12:32 AM
ahunt4's Avatar
Default Constant ticking from under the hood
82 xj6 series 3. When I open the hood at idle there is just this constant tick noise I don't know where its from. It doesn't effect the performance at all when driving. Any idea what it could be. I don't want to neglect it incase its something I should be worried.
Old Jan 21, 2015 | 01:18 AM
Giovanni LiCalsi's Avatar
Try and find an automotive stethoscope and listen closely to the engine.
Old Jan 21, 2015 | 09:48 AM
Saemetric's Avatar
Probably a valve adjustment issue. A slight tick is ok, but a loud clank is not. A valve lash check should be done at some point.
Old Jan 21, 2015 | 05:03 PM
Fraser Mitchell's Avatar
Could be a tappet guide has loosened and is knocking the underside of the camshaft. You need to listen to the cam cover with a mechanic's stethoscope, (a long screwdriver will do with your ear at one end, the blade at the other end pushed onto the outside of the cam cover)
Old Jan 22, 2015 | 12:34 AM
yarpos's Avatar
If it stops ticking either cut the red wire, or run like hell.
Sorry, couldnt resist it.
Old Jan 23, 2015 | 05:13 AM
TNJohn's Avatar
The injectors make a heck of a racket on my car. Listen to them with a stethoscope. That may be what you are hearing.
Old Jan 23, 2015 | 07:08 AM
Jose's Avatar
if you or the previous owner have not installed the tappet guide fix, then that could also be what you are hearing.
My '84 always ticks a little when cold, then the ticking goes away as oil circulates.
Old Jan 24, 2015 | 11:43 PM
Tar's Avatar
Tar
I had a loud ticking noise that turned out to be a defective water pump.
You will need a stethoscope to hear it well, as others have said. You may also be able to test by seeing whether the fan can be 'jiggled' on the pump pulley, although I had a good loud noise without any apparent looseness.
Old Jan 25, 2015 | 02:24 AM
yarpos's Avatar
The mechanics stethoscopes people are talking about can be bought for just a few $ , they are a very handy aid in locating the source of ugly noises.
Old Apr 10, 2015 | 12:47 AM
ahunt4's Avatar
Default Where can I get the tappet guide fix?
Old Apr 10, 2015 | 12:46 PM
Tar's Avatar
Tar
They are usually listed, on the websites of the usual Jag parts suppliers, as "stakedown kits". Take a look. I got mine from Coventry West.
goges
Oct 5, 2015 04:53 PM
jospolice
Oct 2, 2015 07:16 PM
oldjaglover
Sep 29, 2015 03:27 PM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
