Coolant drain location on a series 3
On the cars that *have* a coolant drain it'll actually be in the transmission oil cooler....that cylindrical heat exchanger that attaches to the lower radiator hose.
Later cars usually don't have the drain so you'll have to slightly loosen the lower hose and let the coolant trickle out
why do you want to drain the coolant?
once you disconnect the upper radiator hose, some coolant will drain anyway.
but if you mean draining the entire system for whatever the reason, there is a block Drain on the driver's side of the engine that looks like a tiny faucet and it is there to drain the block.
aholbro1
Dec 29, 2024 06:46 PM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
