Coolant warning light - RESOLVED
Old Nov 19, 2012 | 12:38 PM
Calhale's Avatar
Default Coolant warning light - RESOLVED
Now that the fuel pump circuit is fixed, and the car starts right up, I'm starting the process of investigating why the a coolant warning light on the dash has tripped on in my 85 xj6.
Currently: I have coolant in the reservoir, and am assuming (hoping, really) that this is an electrical lead problem.
I've read the helpful post here: https://www.jaguarforums.com/forum/x...t-light-56901/ but did have a few 'what next' questions:
First off, is there any way to test the coolant sensor?
Second: How about the transmitter under the dash (any way to give it a signal it should interpret as 'okay' so I can see if the light goes off)?
Old Nov 20, 2012 | 01:06 PM
Calhale's Avatar
Wow, that was actually a quick fix -- for posterity it was indeed a loose wire I'd missed the first time.
Old Nov 20, 2012 | 01:18 PM
Result.
I always like the zero cost fixes the best.
Changed your thread title by adding 'RESOLVED' to show it's fixed.
Old Nov 20, 2012 | 01:39 PM
Jose's Avatar
where was the loose wire? at the coolant resevoir tank?
Old Nov 20, 2012 | 01:49 PM
Calhale's Avatar
Yes -- re-seated it and the light ceased firing (I suppose it could be burnt out )
Old Nov 20, 2012 | 08:11 PM
Jose's Avatar
if you pull/pry the indicator lights faceplate, (the black plastic plate between the speedo and tacho), there are spare bulbs there, because some idiot lights are not used in the Series 3, 6-cylinder XJ. just pull the plate with your fingernails.
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
OkieTim
Sep 8, 2015 04:48 PM
edtexas
Sep 4, 2015 08:20 PM
