Correct Me Door Plunger
Old Apr 15, 2024 | 12:39 AM
adenshillito's Avatar
Default Correct Me Door Plunger
i am correct in assuming that a continuity test on these door open/shut signal components should complete a ground circuit when open and break it when close? a very les testing from the screw hole to the bullet should give me a continuity?
Old Apr 15, 2024 | 07:12 AM
Doug's Avatar
Correct.
Open door = closed switch = path to ground.
I suppose some switches may work the other way around, depending what it is they're switching, but I've never seen one.
Old Apr 15, 2024 | 04:27 PM
so if i do a continuity test i should get an on/off single with one tip placed on the screwhole and the other on the bullet connector?
yet out of four of these switches i don't. that don't seem right..
dadspet
E type ( XK-E )
Aug 1, 2024 03:49 PM
mad dog
Jan 28, 2023 04:30 AM
asjdhsajhdfj
Dec 26, 2022 04:22 PM
asjdhsajhdfj
Dec 25, 2022 07:44 PM
