D Jet MAP Sensor
Old Aug 21, 2019 | 05:59 PM
Andrewxjc's Avatar
Default D Jet MAP Sensor
Hello Everyone,
1978 XJC Series 2 V12 D Jetronic FI Australian delivered new.
I've had my MAP Sensor tested by my local Mechanic (no Jag specialists nearby) and the vacuum test shows it holding pressure at -0.5 Bar for 10 seconds. The Resistance between 7 and 15 is 100ohms (should be between 85.5 and 94.5 ohms)
between 8 and 10 is 395ohms (should be between 346.5 and 353.5 ohms)
Are these results too far outside of the parameters?
This is the first thing I've checked in my mission to get the car running smoother. Currently drives well but runs rich. Strong fuel smell and revs increase to 1800rpm occasionally, after longer drive.
Is Dr D Jetronic the only option for repair?
Old Aug 21, 2019 | 08:29 PM
motorcarman's Avatar
Mercedes used a similar unit. You might try to find one to see if it will adjust the fuel mixture within specs?
Old Aug 21, 2019 | 11:11 PM
Yep,
BMW, Citroen, also used that system in teh same years as Jag,
Some of these MAP, have an adjusting screw (allen head) in the snout end. The thread are VERY course, so a small rotation makes a HUGE adjustment to the readings.
Some have a plastic cover on that snout, some do not.
Not holding Vac is the general failure, so with yours holding Vac, you are 95% on a winner.
Old Aug 22, 2019 | 11:03 AM
JagCad's Avatar
I have a vague recollection that Volvo used it as well
Carl
Vik976
Nov 6, 2019 07:59 AM
EsRay
30
Nov 2, 2018 10:49 PM
tycapel7
Apr 22, 2017 11:49 AM
Andreas Schmieg
Nov 28, 2016 02:34 AM
Simprof
Apr 29, 2011 11:16 AM
