Disontinued: cold start injector for XJ6 S3 and others. Any source for a new one?
Old Nov 11, 2014 | 11:56 AM
Paul.S's Avatar
Default Disontinued: cold start injector for XJ6 S3 and others. Any source for a new one?
Bosch # 0280170028
Summit said that Bosch's own shelves were bare. I have found reconditioned injectors, but I would rather buy new while/if I can. Anyone know who might have one in stock? Thanks, -Paul
Old Nov 11, 2014 | 01:43 PM
sunchip's Avatar
Cant you contact bosch directly about this?
Old Nov 11, 2014 | 04:13 PM
Paul.S's Avatar
Bosch sez none. Discontinued 2007, no old stock, obsolete. I hope that doesn't make the whole car obsolete! Those referbs are looking better and better. -Paul
Old Nov 11, 2014 | 05:32 PM
ronbros's Avatar
you can clean them out as long as they show a resistance value, know anyone(dentist), that has an ultra sonic machine.
soak them and try 12 volts to the coil,on-off as fast as possible,apply some pump pressure using kero,diesel something that wont burn easily,(no gas,petrol) with sparks from connections. you can guess why.
Old Nov 11, 2014 | 10:50 PM
Paul.S's Avatar
Was never impressed by ultrasonic cleaners. Used them professionally as a jeweler, they couldn't hold candle to a shot of Scrubbing Bubbles and a toothbrush! Anyone know if they actually do anything for injectors, or is it just advertising hype?
Tried that with carb cleaner, couldn't get a drop or a bubble through at 90 psi. Was going to crank it up to insane, but thought better of it when I found out how hard it might be to replace. Details here: https://www.jaguarforums.com/forum/x...1/#post1099317
-Paul
Old Nov 12, 2014 | 07:18 AM
sdduke's Avatar
I'm sure David Boger at everydayxj.com has them.
Old Nov 12, 2014 | 08:16 AM
Doug's Avatar
I thinking a different part number might work OK.
The Bosch FI system was used on many cars with slight variations. I Googled "Bosch Cold Start Injector" and got lots of hits. Here's one:
Your Parts Search Returned 1 Part(s)
I'm fairly sure that many cars used the same *style* of cold start injector....the one above looks like the type seen in the older Jags, just going from memory.
If you could find one from a car with a 3 or 4 litre engine that looks like the same style, it would probably work just fine. One from a little car with a 1.5 or 2.0 litre engine might not give a big enough squirt due to being calibrated for a smaller engine.
Anyhow, it might be worth a little research?
Old Nov 12, 2014 | 11:37 AM
Bryan at Coventry West's Avatar
We've got a couple of new aftermarket reproduction cold start injectors still available if you're interested in going that route.
EAC1383# INJECTOR, COLD START
Use coupon code JF10 for a 10% discount, or if you prefer to call us about it, just mention to your salesperson that you're a Jaguarforums.com member.
Moderators, if this is inappropriate for this specific forum, just let me know.
Old Nov 13, 2014 | 10:58 PM
Paul.S's Avatar
Thanks for the tip! He has great prices on other stuff I need too. The price is right for a cold start injector, but unfortunately they have not been flow tested. If I can't find a new one soon, I may take a chance. -Paul
Old Nov 13, 2014 | 11:20 PM
Paul.S's Avatar
I checked the images that came up on a google of “cold start injector” and saw an identical looking part: Land Rover EAC1383L. It even shows up on a cross reference to the Bosch part. Unfortunately, it appears to be even harder to find. If I had the time I would probably buy this:
Land Rover Fuel Injectors Range Rover Classic EAC1383L | eBay
I've been seeing many with the same flange, that is encouraging.
I think that one would work fine, if I could find a barb fitting for it, or a 5/16 hose with the right fitting on one end.
I think so too. My Jag seems happy with most any size blast of starting fluid I give her, I don't think an exact match would be necessary. -Paul
Old Nov 13, 2014 | 11:26 PM
Paul.S's Avatar
Good to see them available in the states. If I can't find the Bosch part, I will probably go with that. How soon could you get it to Grand Rapids MI 49503?
Old Nov 14, 2014 | 09:36 AM
It would take approximately 3 business days to get it up there to you.
Old Nov 15, 2014 | 12:14 AM
Paul.S's Avatar
Dave at everydayxj.com really came through for me. His injectors weren't flow tested and I didn't want to be put further behind on this project while a clogged injector was cleaned or exchanged, so I ordered 2. He gave me a package price on 2, figured out a way to get them to me next business day for $5, and threw in an extra one with a defect that probably wont interfere with its function! And if I pay to get a couple of them referbed I will still be out less that the cost of 1 referbed injector on Ebay, and probably end up with 1 good injector in the jag and at least 1 spare. I wouldn't have dared to ask for a deal this good. I know where I will be looking first when I need more jag parts! -Paul
Old May 17, 2016 | 07:49 AM
fischp's Avatar
Default Need a better way...
Hi all,
I'm in the process of getting a 1983 XJ6 running so I can flip it, and have a bad cold start injector. It seems hopelessly clogged. The electrical parts are good in the injector, I hear it click, but I can't even blow though it. I've had the injector soaking in Gum Out for several days now. Will check it again but don't have much hope.
Has anyone found a suitable substitute for the injector? Preferably not over $100?
Thanks!
Old May 17, 2016 | 08:27 AM
JagCad's Avatar
Seems like at least two great options. Coventry West and
everdayxj. As good as it gets!!
Carl
Old May 17, 2016 | 08:49 AM
Jagfixer's Avatar
Soaking in Seafoam works better than Gumout.
Old May 17, 2016 | 09:35 AM
fischp's Avatar
I'm getting ready to use brake cleaner. I'll try Seaform as well before then.
Has anyone had any luck using compressed air and blowing the injector from the reverse (output) direction with it energized?
Old May 22, 2016 | 09:51 AM
Jose's Avatar
order the aftermarket part, it is probably better than the Bosch part.
Old May 22, 2016 | 05:24 PM
motorcarman's Avatar
Y'all keep calling it a Cold Start Injector when the correct designation is CSV (cold start valve).
Try this!!!!!!!!!!!!!!!
Fuel Injection Cold Start Valve Standard CJ50 | eBay
Most 'L' Jetronic fuel injection systems used a Cold Start Valve but some of the German cars with 'K'Jetronic used one with a BANJO fitting instead of the hose connection for fuel inlet.
Datsun 280 Z used one but the nozzle points to the side (I think).
bob
Old May 22, 2016 | 05:49 PM
Doug's Avatar
The confusion comes right from Jaguar itself, as the S57 wiring guide, parts catalog, and ROM all refer to it as "cold start injector".
Most others do use the 'valve' terminology, in my experience
