Distributor timing help
Old Aug 2, 2019 | 10:08 PM
neinz's Avatar
Default Distributor timing help
The factory workshop and Haynes manuals both state that 8 degrees BTDC needs to be set with the distributor rotor facing the cylinder 6 position. Does that sound right to anyone else? I’ve done a forum search and haven’t found anything definitive regarding this. Thanks!
Old Aug 3, 2019 | 01:18 AM
Memory?????
As fitted, before fiddling with, the rotor did point in the general direction of #6 cyl, at TDC #1 compression stroke.
#6 is the front cylinder on these.
Since the distributor is an offset tang drive, pretty straight forward.
Old Aug 3, 2019 | 02:06 AM
neinz's Avatar
Originally Posted by Grant Francis
Memory?????
Thank you very much, Grant! Much appreciated.
Old Aug 3, 2019 | 06:45 AM
Yellow series3's Avatar
Note that the timing setting varies by model year. If you can find a sticker under the hood somewhere with the settings, that is the best. Otherwise make sure you find the correct year specific settings for you engine.
Old Aug 3, 2019 | 07:02 AM
neinz's Avatar
Will do, thanks!
Mia Mi
Mar 17, 2019 12:02 PM
OES
Mark V - X 420G
Feb 28, 2017 01:46 AM
Ol Blue
E type ( XK-E )
Dec 7, 2015 10:59 PM
evo mrt
Nov 29, 2011 04:15 PM
jjd
Dec 28, 2010 03:35 PM
