engine dies while running after some time
Old Jun 6, 2017 | 06:08 PM
1985jaguarxj6's Avatar
Default engine dies while running after some time
Hello,
I have a 85JagXJ6. The engine will start fine and idle for many hours. Now when I start driving after 45 mins to 60 mins it will stall then engine die. I will wait for 20 to 30 or so then it will start again and run.
Would anyone have this issue before? Could you please tell me how I can resolve the this issue, I really love my 85JagXJ6.
Thank you very much.
SanJ
Old Jun 6, 2017 | 08:23 PM
Mad Hatter's Avatar
Vapor lock?
Old Jun 6, 2017 | 08:54 PM
o1xjr's Avatar
Welcome to the forum SanJ. please post an intro in the new member area for a warm welcome.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Jun 6, 2017 | 08:59 PM
Doug's Avatar
Originally Posted by 1985jaguarxj6
Hello,
SanJ
Both the ignition module (AC Delco #D1906) and the ignition coil are known to give trouble when hot and then work OK again after cooling down.
Next time this happens check for spark at the plugs. No spark or a weak spark obviously suggests an ignition problem. If spark is strong then explore fuel system possibilities
Post back for more details, if needed
Old Jun 7, 2017 | 09:56 AM
JagCad's Avatar
I suppose one could apply an ice pack to each and see if the engine fires up.
Or a blast of CO2!!!!
Carl
dlatimer
Mark V - X 420G
Aug 9, 2017 07:25 AM
Shane7
Nov 17, 2016 04:39 PM
Stoney85
Oct 11, 2016 06:24 PM
Randy
Jun 20, 2008 08:05 PM
erich
Apr 28, 2008 02:12 AM
