finding vaccum leak
Old Nov 30, 2021 | 03:03 PM
robroy's Avatar
Default finding vaccum leak
I have a 87 jag xj6, and I suspect a theres a vaccum leak. What is the most efficient way to fond a vaccum leak??
Bob
Old Nov 30, 2021 | 04:13 PM
Fraser Mitchell's Avatar
Modern practice is to carry out a smoke test.
https://roadsumo.com/smoke-test-car/
I've never had one done, or even seen one done, but there was a YouTube video some months ago by the Car Wizard on this technique.
Old Nov 30, 2021 | 05:58 PM
Jose's Avatar
get a Habana cigar, light it, take a big puff and blow it into any vacuum line. Keep blowing and smoke will come out where the leak is. Do this with engine OFF. Enjoy the cigar.
Old Nov 30, 2021 | 07:32 PM
robroy's Avatar
I smoked cigars for 15 years, but quit 4 years ago. I've been looking for an excuse to light up, and you just gave it to me
Thanks !!
Bob
Old Dec 1, 2021 | 04:49 AM
Jose's Avatar
Old Dec 2, 2021 | 07:05 PM
lickahotskillet's Avatar
Long fuel hose on a Burns o Matic. I take the jet out of mine. Cracking the valve slowly near gaskets and hoses - listen for a RPM increase.
Old Dec 10, 2021 | 07:25 AM
jpipe's Avatar
Same suggestion as above, but use "Easy Start" (Ether).
Old Dec 10, 2021 | 09:24 AM
Problem with ether and carb cleaner is to volatile. They head to the intake and fool you in the diagnosis. Propane is heavy & drops. Lessens the chance of miss diagnosis. The valve on the burnz a matic. Let's you dispense small amounts when you are looking for a change in rpm. If the system is already too rich - rpm goes down. Lean - rpm goes up.
asjdhsajhdfj
Jun 4, 2021 09:39 AM
flatlander
Mar 20, 2017 10:18 AM
roger ele969c
XJ40 ( XJ81 )
Jun 10, 2011 05:52 PM
jimmycruz99xjr
Feb 1, 2011 11:01 AM
SeismicGuy
Jan 3, 2010 07:35 PM
