Front end alignment
Old Jul 21, 2014 | 07:50 PM
sneal46's Avatar
Default Front end alignment
It has been a while since the jag has acted up with something that wasnt easy to fix. That came to an end today. Noticed wear on both inner front tires. Car did not steer poorly tho. Took it in for an alignment and the shop said not matter how they moved the shims, they could not get the camber closer than -1.3 on either side. Any thoughts as to why that is the case?
Ball joints, tie rod ends, and tires all new within 10k miles. What other front end parts could cause alignment issues?
Old Jul 21, 2014 | 09:12 PM
sneal46's Avatar
I will add now that the toe is aligned, it drives and steers perfect. The wear will show over time though.
Old Jul 21, 2014 | 09:45 PM
icsamerica's Avatar
The lower control arm bushes are probably worn out which will through off the geometry over all especially the camber.
Old Jul 21, 2014 | 09:53 PM
sneal46's Avatar
Oh man I bet that is it.... those are the one thing I did not replace yet.
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
bamforp
Aug 14, 2024 05:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
James007
Oct 3, 2015 03:29 PM
