fuel c/over switch
Old Jul 13, 2014 | 12:05 AM
oldjagowner's Avatar
Smile fuel c/over switch
I have a xj6 ser3 1985 car and am trying to change the fuel switch over the manual don't tell me anything can some one please help an old man thanks
Old Jul 13, 2014 | 06:04 AM
Doug's Avatar
You didn't say what problem you're having, specifically.
The switch is held into the panel by little tabs. These need no be pressed inward to release the switch. The only way I can think of doing this is to release the panel so you can get your hand behind it.
My memory is a bit foggy on the details, but.....
If you look above the radio you should see two screws. Remove the screws and the panel can be wriggled downward and then outward. Gently. The top edge of the panel has two 'tab-A into slot-B' arrangements.
If you have a trip computer you'll have to remove it first. Easy. It comes out from the front. Just get your fingernails under the edges and wriggle it out
Not sure if the radio needs to be removed as well. Someone with a better memory will chime in.
Old Jul 31, 2014 | 05:52 AM
thanks guy problem now resolved
Rivguy
Nov 13, 2022 02:55 AM
ratgawd
Sep 16, 2015 04:15 PM
jagent
Sep 12, 2015 09:10 AM
1964Daimler
Sep 9, 2015 11:28 AM
Bones
Sep 8, 2015 08:34 PM
