Fuel Filter Question
Old Jan 20, 2015 | 08:54 PM
ahunt4's Avatar
Default Fuel Filter Question
Ok this may sound silly but I took out my fuel filter and let all the liquid in it drain (I did install a new one). I decided to test the old filter by pouring some water into the flow direction, no water came out the other side. My question is is that should water be able to drain out the other end with no pressure and just from gravity? Was thinking it was very clogged if no water came out the other end. Thank you
Old Jan 20, 2015 | 08:57 PM
dave308's Avatar
water will not pass through the filter unless under pressure , Just blow on it and see if it feels restricted
Old Jan 20, 2015 | 09:31 PM
That filter is doing exactly as designed.
Same for any EFI filter.
aholbro1
Dec 29, 2024 06:46 PM
Sprayall
May 30, 2021 08:13 AM
teacoff
Sep 10, 2015 08:25 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
Sprayall
Sep 3, 2015 07:49 PM
