Fuel Pump Relays - 1978 XJ6
Old Jan 25, 2015 | 09:48 AM
kev53's Avatar
Default Fuel Pump Relays - 1978 XJ6
I have 1978 xj6 with twin carbs, would anyone have wiring diagram for fuel pump system or know the location of fuel pump relays.
Old Jan 25, 2015 | 10:08 AM
Welcome to the forum kev53,
I've moved your question from UK & Eire Region to XJ6 Series I, II & III forum. Members here with the same model will be able to help.
Old Jan 25, 2015 | 12:56 PM
icsamerica's Avatar
Welcome to the forum. I have no doubt you will find the enthusiasts here helpful.
That said i dont recall a fuel pump relay on my 76. There is a pair of white wires that come off the tank selector switch run over to small fuel pump located inside of each fuel tank. There also is a saftey inertia switch found on the right hand or US passenger side A pillar that interueps current in the event of a crash. If trippped it can be easily reset.
Old Jan 25, 2015 | 02:05 PM
kev53's Avatar
I have checked wiring at the pumps found it ok, inertia switch not tripped however if i put 12 volt to wire at inertia switch the starter engages, i would be surprised if there is not relays controlling the fuel pumps.
Old Jan 25, 2015 | 08:07 PM
icsamerica's Avatar
I just checked the wiring diagram and the white green and white purple wires off the tank selector switch go directly to the fuel pumps. No relay.
Old Jan 26, 2015 | 07:28 AM
kev53's Avatar
Thanks for that i will check wiring from switch to pumps as everything else seems ok
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
deanh
Sep 6, 2015 08:20 PM
Sprayall
Sep 3, 2015 07:49 PM
