fuel tank problem
Old May 20, 2019 | 02:54 PM
Fred Archer's Avatar
Default fuel tank problem
Hi ,my 1979 xj6 mark2 fils the one tank from the other,why.
Old May 20, 2019 | 03:23 PM
David84XJ6's Avatar
Fred
See Diagram item # 12 Change-over valve, leaking or stuck half-way open. Fuel Change-over Valve P/N CBC4269 Can be found by removing trunk board to get to spare tire. (Diagram is for S3 so may be some differences in S2). Some have had luck cleaning insides with carb cleaner; if your tanks are full you are going to get a lot of gas spill, be prepared or as Doug would do, stick some pointed 1/2" wooden dowels into the hose as you pull it off valve nipple.
Old May 20, 2019 | 08:41 PM
Yellow series3's Avatar
My 87 would draw from whichever tank I selected but always sent the return to the right tank, never the left. It seems the electrical connections for the return valves in the rear wheelwells were corroded. I fixed those connections and everything works properly now.
Old May 20, 2019 | 09:19 PM
David84XJ6's Avatar
Originally Posted by Yellow series3
My 87 would draw from whichever tank I selected but always sent the return to the right tank, never the left. It seems the electrical connections for the return valves in the rear wheel-wells were corroded. I fixed those connections and everything works properly now.
Fred, I may have miss read your question, If one tank is filling from the other while driving, then as said above, it's the return valve (#2) not operating properly (electrical problem or the valve is gummed up)
Rgds David
86jag
May 12, 2023 07:06 PM
XJDanny
Mar 16, 2019 05:04 PM
Testie
Feb 5, 2019 05:36 PM
Bamaman
Jul 28, 2011 12:46 AM
cbomb
Sep 14, 2008 12:39 AM
