Gauze filter on chain tensioner.
Old Jun 3, 2019 | 02:19 AM
Howie1971's Avatar
Default Gauze filter on chain tensioner.
Hi all, stripped down series 1 engine to have it machined but trying to find this filter, can anybody shed some light on this is it behind the dowel that locates the timing tensioner on the block.? Getting the engine fitted with stepped liners, piston etc, so wanting to replace it for when they put it in a tank for cleaning. Doing a full rebuild so want it all done right. Cheers Howie.
Old Jun 3, 2019 | 04:07 AM
Damn, thats stretching the memory.
NO, it not behind the dowel, it is a conical filter inside the oil passage that feeds the tensioner, and installed pointy end first.
May not even be there, as a few I have rebuilt have not had them installed, so maybe someone has been there before.
#20 in this parts book drawing.
Old Jun 3, 2019 | 04:13 AM
Fraser Mitchell's Avatar
Grant, you are absolutely correct ! I do remember taking mine out and cleaning it before reassembly of the timing gear. I have to say I'm not sure if it does have any real benefit, although the hole in the chain tensioner that takes pressure to the piston is very small, so might easily clog up without it, I suppose.
Old Jun 3, 2019 | 04:25 AM
Agreed Fraser, and we all know how WELL these engines have been cared for before we got them????
With the new breed of owners, and the new breed of oils, maybe not so big an issue, but the work if that tensioner hole does clog up, is unthinkable.
Old Jun 3, 2019 | 08:37 PM
Howie1971's Avatar
Found it! was behind the dowel. Googled the tensioner and by photos the dowel should be in it not the block.
Cheers Howie.
tonycharente
XK120 XK140 XK150
Jun 17, 2016 07:21 AM
Mike:P
Feb 6, 2010 05:18 PM
n17gary
Mar 11, 2009 04:28 PM
GordoCatCar
Aug 2, 2008 01:02 PM
2000blackxkr
Aug 31, 2007 05:59 PM
