Grease Nipple Location 87 XJ6 4.2L
Old Aug 25, 2013 | 12:09 PM
WhiteCat's Avatar
Default Grease Nipple Location 87 XJ6 4.2L
Would someone know where I can get a diagram of where the grease nipple locations are on a 1987 XJ6 4.2L Thanks
Old Aug 25, 2013 | 02:55 PM
Fraser Mitchell's Avatar
Its probably in the Workshop Manual or the Maintenance manual, (or both). There are an awful lot of them ! As a 1987 car, it probably has the later XJ40-type front suspension ball joints which have no grease nipples. These items do, however, last almost for ever in comparison to the earlier type designed in 1955.
Old Aug 25, 2013 | 06:11 PM
WhiteCat's Avatar
Thanks for your comments
Old Aug 26, 2013 | 03:42 AM
I've checked the Series III Service Manual and there is no illustration or listing of grease nipples.
From memory:
1. U/J's on the rear drive shafts (the inner ones next to the diff are especially awkward to reach) - 4 in the spiders
2. rear hub lower pivot - 1 in the centre
3. Prop Shaft U/J' - 1 in each spider
4. prop Shaft sliding joint
5. Front suspension older pattern upper ball joints
Old Aug 27, 2013 | 01:11 PM
WhiteCat's Avatar
Thanks, much appreciated
Kevin Burnaby
Jun 28, 2020 08:04 AM
rusty37
Apr 5, 2020 07:40 PM
Jeff4605
Oct 7, 2015 07:47 AM
Charlene n John
Sep 14, 2015 12:01 AM
Gatsby
Sep 6, 2015 11:52 AM
