Grease Points
Old Nov 3, 2018 | 02:10 PM
Flappers's Avatar
Default Grease Points
Hi can anyone help me find all the nipples on my series lll double six please I'm going to disappear under it next week and don't want to miss anything. (any tips on the type of grease?) And how do i grease the hubs please?
Regards Sam
Old Nov 3, 2018 | 02:45 PM
Doug's Avatar
The total number might depend which, if any, parts have been replaced as some replacements don't have grease fittings.....ball joints and u-joints specifically
Anyhow......
Upper and lower ball joints. That's four.
Three propshaft u-joints. That's seven.
Four half-shaft u-joints. That's eleven.
One on the bottom of each rear hub. That's thirteen.
Two on each rear fulcrum arm near the diff. That's seventeen.
One on each front hub. That's nineteen.
I think that covers it. Other might have a better memory.
I use wheel bearing grease.
The manual says add grease to the front hubs until it oozes out of the bleed holes in the dust caps. That's better than nothing but, IMO, this is the not same as a good, old-fashioned period 'bearing repack' where you remove the hubs, clean and repack the bearings, and replace the seals.
In additional to the fittings at the bottom of each rear hub (for the pivot shaft) there are two removable grease plugs up higher on the rear hubs for the rear bearings. The process here id very iffy. All you can do is squirt in a bunch of grease and hope some if actually gets into the bearings.
Winks
Nov 17, 2014 08:38 AM
suprasix30
Mar 4, 2014 03:43 PM
ArtyH
Oct 11, 2013 05:34 PM
tmill051
Aug 23, 2010 10:23 AM
newquaymarc
May 4, 2009 04:04 PM
