green/red wire to air con?
Old Jun 10, 2024 | 08:08 AM
mickvic's Avatar
Default green/red wire to air con?
theres a few wires seem to hug the right hand side of the block up near the head. Red green, (which has insulating cracked and open, a brown and a white which is just hanging there. Now the air con fan does not turn on at the moment it did when I bought the car but has pretty much failed since.
My electical abilities are lousy btw, Those wires I mentioned ot a blurry photo below seem to go round the front of the block and duck over to a relay roughly attached to the compressor.
Would these wires be operational for the air con and fan, and if so would there condition coause it to be innoperative?
Old Jun 11, 2024 | 06:58 AM
Doug's Avatar
The green/brown wire comes from the cabin to turn the a/c compressor on/off. Originally it went to a "thermal limiter fuse"....which on your car seems to have been replaced by a relay.
If the green/brown wire is shorted to ground it would blow a fuse and could make the blower motors inoperative, yes
White/brown goes to the sending unit for the oil pressure gauge
littlelic69
19
May 11, 2024 11:10 AM
Zakarayas
XJ40 ( XJ81 )
Nov 23, 2023 04:26 PM
brinny
Aug 21, 2023 12:29 PM
Jagfix38
XJ40 ( XJ81 )
Dec 19, 2012 03:17 PM
Vee
Sep 5, 2012 04:53 PM
