Headaches Need HELP!!!
Old Mar 10, 2015 | 01:34 PM
Ltarr's Avatar
Default Headaches Need HELP!!!
I have a 1981 Jaguar XJ12 V12 (5.3L) car was made in febuary of 81 and I am certain it is pre-HE. The problem I am facing is overfueling badly the exhaust fumes make my eyes water and I think there is now gas in the oil, bumper is also black with soot. it has 60,000km on it. All stock except the P.O put a Crane Cams Fireball ignition on it, model # XR700 and he told me that he could not get injector pulse then when i went to pick it up he had ran a wire from the ECU to the coil and now it runs but it runs very rich. Do you think it's the ignition? I have no idea as to why it runs with that wire but not without, thanks in advance for any help
Old Mar 10, 2015 | 03:17 PM
icsamerica's Avatar
Default tings...
Check the coolant temp sensor.
See this link for more info...
https://www.jaguarforums.com/forum/x...-sought-33273/
Check the air intake temp sensor in the case of the driver side air cleaner, typically comes disconnected or suffers a broken wire.
Check the vacuum hose that T off the manafolds and go to the MAP sensor located on the radiator support. Make sure the hose is not leaking and that you have a good vacuum signal.
Old Mar 10, 2015 | 03:52 PM
icsamerica's Avatar
Check these too...
Ignition Amplifier Replacement
JAGUAR V12 FUEL INJECTION 1975-1980 - D Jetronic / AJ6 Engineering
Check the Fuel injection trigger board in the dist. What exactly is the wire from the ECU to the dist? If its give 12 pulses every 4 revolutions it's too much. I think the Fuel injection system, is a batch fire two pulse system and the fuel injection auxilary amp splits it across 3 banks for use on the V12.
Old Mar 11, 2015 | 10:03 AM
Ltarr's Avatar
the wire goes from the ECU to the Coil not to the distributor
andrac
Nov 4, 2013 09:58 AM
jaguar lover
29
Apr 27, 2013 02:26 PM
1stone98xjr
Mar 21, 2013 12:20 PM
Spyke
Mar 2, 2011 06:32 AM
StrateLoss
Sep 26, 2010 07:47 PM
