Headlamp Idiot Lights Series III
There are two lights in a row at the top of the idiot light asdembly on a Series III. The left ones is blue and looks like a headlight icon shooting straight, whereas the right one is yellow with a headlight dipping down. I'm trying to hook these up and I don't know what each icon means.
I'm sure you guys know. Thanks
the yellow one is for REAR fog lamps as used in Europe. Disabled for the USA.
the Blue one is the High Beams indicator. If it is not coming on when you pull the turn signal switch, the bulb must be out.
My project is deleting my surface cracked Series II eood dash with a new Series III I've had in storage for over 15 years. And as you know the idiot light assembly is different both in size and wiring. So that was my project tonight. Thanks for the input.
dleckste
Sep 2, 2021 07:23 PM
