Heater Pulley Rig
Old Apr 30, 2021 | 06:36 PM
adenshillito's Avatar
Default Heater Pulley Rig
Does anyone have a simple digram that shows how/where the tension wire from the jockey pulley on the base of the series 2 heater travels to? Looking at it I can't tell whether it means to have more than one wire or why it has two wheels etc. Can see it has been repaired in the past.
exacted pulley from beneath air bender unit series 2 xj6
Old May 9, 2021 | 02:55 AM
Default Pulley 2#
The Hayes book doesn't show it but talks bout it. I follow how I can attach the wire to the rear/second wheel but how I string the wire around the double-wheeled at the front? Once? Twice, Cris-Cros.? Any thoughts?
Old May 9, 2021 | 10:32 AM
I wonder if your system predates mine. Every picture I have relates to rods moving flaps with not a pulley in sight.
I'm sorry, but I don't think I can help with this one.
Old May 9, 2021 | 06:38 PM
All the forum posts and Google images of the air bender suggest it is a more primitive model as it only has a single flap door at top and has this strange pulley linked to the flap control. Latter models seem to have a complex box of rods and an amplifier instead.
Old May 9, 2021 | 08:05 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
Gary Crosby at Jag-Aire might be able to help.
Dave
Old Jun 6, 2021 | 02:50 AM
Default Heater Flatps
Gary was indeed very helpful and had not come across this unusual model before but dug out some spec diagrams for the beast. As I continue to try and piece it together I realise the short comings of my education in pulley physics.
I have used wire fishing line and crimps of 0.7mm to match the original wire. PROBLEM I have now is figuring the 'set' position of some of the internal flaps of the heater. (see pictures) I am not sure (a) if the wire original wire had a spring at either end or just one at the left as in the diagram, and (b) whether the armature is in closed or open position when the pulley tension in pulled left or right (or knob position at top or bottom). This armature effects the lower flap near the floor of the unit but I cannot figure whether having the FLAP CLOSED stops HOT AIR traveling into the cab of the car OR whether having the FLAP OPEN dilutes the hot air with a cold intake to reduce heat. I can imagine it could be doing either. The knob set to top is HOT and set to bottom is VENT.
The Heater Only Series 2 unit that I have.
the armature as positioned with the lower/floor flap inside the heater in it's OPEN position
the armature as positioned with the lower/floor flap inside the heater in it's CLOSED position
ashbypa
Mar 23, 2017 07:28 PM
trucknetjack
May 1, 2015 03:40 AM
XxSlowpokexX
Jul 18, 2014 04:14 PM
XxSlowpokexX
Jul 17, 2014 10:42 AM
super_jag
35
Mar 8, 2010 03:25 PM
