Heater vacuum valve assembly located? (S1)
Old Nov 21, 2023 | 11:59 PM
Imono12345's Avatar
Default Heater vacuum valve assembly located? (S1)
Hi! As winter is coming around and my car will be sitting around for most of it, I want to take care of some small things.
dies anyone know where this valve is located?
I can’t follow the vacuum lines because they are coupled completely wrong and was hoping to set things right so I can change the airflow and heat.
All answears are appreciated!
Old Nov 22, 2023 | 12:35 AM
The Mekon's Avatar
This valve is behind the centre console panel which houses the heater controls and usually the radio. Once the vent controls and radio are removed, remove the chrome finisher panel. Then remove the black steel panel.
Warning! be very careful with this valve. The plastic barbs break off very easily. You will be very lucky to find a good used unit if yours is broken.
Old Nov 22, 2023 | 12:39 AM
Imono12345's Avatar
Thank you mekon!
Will probably take a look at the radio too when doing this.. it worked sometimes when I got the car but now not at all.
the power cable for the radio was wired in to the fuse for dials and the horn, and all of those things were funky until I changed the fuse but now the radio doesn’t start..
petemohr
Dec 1, 2021 08:14 PM
Roger95
XJ40 ( XJ81 )
Jan 6, 2021 05:07 PM
Jacko5711
Dec 8, 2020 01:12 AM
adenshillito
Feb 8, 2016 10:41 AM
twncty
Aug 4, 2014 02:11 AM
