Help identify relays
Old Dec 30, 2024 | 06:11 PM
Jeffkrell's Avatar
Default Help identify relays
I need some help identifying these relays 1975 xj6c
thank you
rear bench lower bulkhead
above fuse box left side
below, near gear shifter
also this one has Weber carbs. Looks like a nice setup. Is this common? A good carb. ? Started right away with fuel in carb..
Old Dec 30, 2024 | 08:48 PM
Doug's Avatar
Pic #1 might be the starter relay.
Pic #2 looks like power locks. Is it under the rear seat?
Pic #4 those 2-prong black units are circuit breakers
Tell us the wire colors. That often helps
Old Dec 30, 2024 | 09:23 PM
Jeffkrell's Avatar
Ok. I’ll take picture with wires.
#2 power locks. I don’t understand why I hear power locks on the back of the coupe. Sounds like the coupe has power locks in the un openable doors…
Old Dec 30, 2024 | 11:50 PM
Doug's Avatar
I think you're hearing the relays clicking under the rear seat
04Xjrsteve
Jun 16, 2024 04:11 PM
irab88
General Tech Help
Dec 27, 2023 06:58 PM
NYCJAG2006
Nov 23, 2023 12:24 PM
67Camaro
Nov 30, 2021 11:01 AM
