Help w Wire fix
Old Oct 8, 2017 | 03:52 PM
doghead08's Avatar
Default Help w Wire fix
I just notice this wire busted off this connector. Can anyone help with the 411-purpose and best way to fix it
Old Oct 8, 2017 | 03:54 PM
doghead08's Avatar
It ripped out of that connector w the Green writing
Old Oct 8, 2017 | 04:03 PM
doghead08's Avatar
Old Oct 8, 2017 | 04:48 PM
doghead08's Avatar
The 2 outside wires separated from the connectors. Both obviously have something to do with the car starting because now it won’t turn over
Old Oct 8, 2017 | 05:05 PM
Doug's Avatar
The thingy with three electrical posts is the thermal fuse for the a/c compressor protection circuit.
Shouldn't have anything to do with starting/running unless someone ahead of you has really been monkeying around with things.
The connector body often breaks apart. You can reattach the wires to the thermal fuse using ordinary crimp-on/solder-on terminals.
The thermal fuse posts should be marked A B C
A- Black wire
B- Green/brown wire
C- Green wire
Old Oct 8, 2017 | 05:34 PM
doghead08's Avatar
That’s certainly a relief. Cars been starting fine the last 2 weeks. Been my everyday ride. Not sure why all of a sudden it is giving me an issue. Cranking nicely just not turning over Right away. I have to crank crank gas gas and it will start but it’s a struggle. Like trying to get little Damien to go into church.
Old Oct 16, 2017 | 10:37 AM
Saemetric's Avatar
Leave foot off gas pedal when cranking to start engine—always!!
Old Oct 16, 2017 | 10:44 AM
JagCad's Avatar
YUP.
Unlike cars with carbs and acceleration pumps FI cars need no pedal.
Application might merely make matters worse, adding air, when less is needed.
Carl
