High beam
Old Sep 17, 2020 | 03:03 PM
Joey T's Avatar
Default High beam
Hi all, need some input on high beam switch. 1985 series iii 4.2 I can’t turn the high beams off. Any suggestions why would be
appreciated.
Old Sep 17, 2020 | 05:25 PM
Jose's Avatar
start by rolling the fuses in the 5-fuse fusebox located near the coolant filler tank in the engine compartment. Removing the fuses and cleaning them, inspecting them is better. The 5th fuse is for the auxiliary electric cooling fan located below the front bumper.
Old Sep 17, 2020 | 07:24 PM
Doug's Avatar
appreciated.
The relay is probably stuck. It's a 'latching' relay. The stalk switch triggers the relay be grounding it. Each time the relay operates it latches or unlatches.
Do you hear the relay click when you operate the stalk? If so, then the relay is working but I suspect the latching mechanism is broken inside the relay.
If you don't hear a click.....
Remove the blue/black wire from the relay. Use another wire to ground the now-vacant terminal. If the relay now operates then your stalk switch isn't completing the ground circuit
Old Sep 18, 2020 | 06:12 AM
Joey T's Avatar
There isn’t a click.I suspect it’s the stalk not grounding. The relay is a reconditioned one I put in to see if it would solve the problem. I’ll
check it anyway,just in case. The fuses also. What’s the the best way to check the stalk switch?
Old Sep 18, 2020 | 06:38 AM
Doug's Avatar
Go to this thread and look at post #6. It's shows the ground tab at the base of the stalk and the blue/black wire. You should see the same or similar (I've seen a couple different style tabs) and fixed them just by cleaning them.
https://www.jaguarforums.com/forum/x...f-time-234078/
You'll have to remove the column shrouds to see this. Or at least the lower one. Be careful when handling them; they're fragile. And don't over-tighten the screws on reassembly
Old Sep 21, 2020 | 06:24 AM
Joey T's Avatar
Doug, the only blue black wire I see on the relay also has a red wire attached to it.
Is that the same wire you mentioned?. Also, is there a trick to getting the top half of the steering wheel shroud off to get a better look at the contacts? Thanks, Joe
Old Sep 21, 2020 | 07:58 AM
Doug's Avatar
Your probably seeing the capacitor, which is covered in red insulation.
Proceed as planned
Once you have the bottom shroud off look underneath and you'll see one or two screws that hold the upper shroud to a metal bracket. Remove those screws and wriggle the shroud away.
If the shroud doesn't want to come away, don't force it. Lower the steering column a bit. This is very easy. Remove the under-dash trim panel and loosen (don't remove) the two large-ish nuts that support the steering column. This allows the entire column to drop down a bit.
jordanmc
Sep 19, 2019 07:40 AM
kj217
Nov 23, 2014 12:00 PM
tvn300
Feb 13, 2010 07:48 AM
jvegas
Sep 10, 2008 07:35 PM
