High Idle Speed and Lack of Engine Braking
Old Jul 22, 2016 | 06:08 PM
Wayne'sJaguar's Avatar
Well, today I checked out the AAV repair; the idle was most definitely lower. Went from about 1400 rpm to about 800, and I was able to adjust further with the idle bolt on the AAV. So, I am thinking that problem is resolved although I will likely convert it back if and when I am able to get a replacement heat bulb for the AAV, or a used AAV that is not so expensive!
Did not have time today to follow that rubber line at the left air cleaner location........hope to follow that one this week-end!
Now, on to the next problem.......I will start a new subject posting for it.
Thank you again for all the help in working thru the fast idle problem!
Regards,
Wayne
Spikepaga
Sep 7, 2016 01:58 PM
dinop
Jun 14, 2016 02:48 PM
XXCalibar
Mar 29, 2016 05:20 PM
Jun 21, 2012 04:31 AM
Feb 13, 2006 11:40 PM
