How good is this forum
Old Nov 25, 2019 | 12:44 AM
Alan E L's Avatar
Default How good is this forum
Hi all,
just how amazingly good is this forum! And that is a rhetorical statement not a question.
A couple of days ago I posted that the starter motor was not cranking on my V12 after conducting work on the fuel rails. I was dreading the prospect of trying to remove the starter motor which is precisely positioned to make the job a nightmare.
Almost straight away an answer came back from Gary Francis telling me exactly where to look (relay against the firewall) and sure enough I had knocked off a connector. So well hidden was the offending wire once it was off that I could have searched the engine bay for an eternity before I found it.
Wire pushed back on to it's spade terminal and instant start. Thank you Gary, thank you forum
Now, if only I could be so fortunate with my troublesome XK8 that has decided to lose it's power steering.
As an aside, whilst the V12 is complex and many aspects are poorly executed it is reasonably easy to understand
regards and thanks
Al
Old Nov 25, 2019 | 01:22 AM
BEER TIME.
Now we only need to apply that same simple stuff your "possessed" XK8. Might lead to HARD liquor me thinks.
Simple cars these Jags, HA.
Old Nov 25, 2019 | 05:06 AM
o1xjr's Avatar
I agree with you Al, I have had my XJ6 for almost 6 years. Between Grant Francis and other members here they guided me through a 3-4 year mechanical restoration while still being able to use the car as a daily driver most of that time.
The info and help from this forum is priceless. As is the banter between members in a lot of the threads.
Old Nov 25, 2019 | 06:13 AM
XJDanny's Avatar
Without this forum (and the Jag Lovers forum), I wouldn’t want to own my car. The wonderful people on this forum has made owning a Series III a relatively easy experience. Thank you to all who have helped me along the way! :-)
Mark Bialzik
Jul 16, 2019 10:02 AM
johncf
Apr 29, 2017 01:39 PM
Daim
Oct 5, 2014 06:14 PM
85XJ6JAG
Aug 16, 2014 01:27 AM
DaleD
Feb 18, 2010 02:06 AM
