How much can it handle?
Old Apr 19, 2023 | 12:21 PM
BigNorm's Avatar
Default How much can it handle?
Hey guys, I was wondering how much torque can the automatic transmission handle on a xj6 series 3? (3-speed Borg-Warner Model 12 automatic). Can't seem to find the information anywhere.
Thanks in advance.
BigNorm
Old Apr 19, 2023 | 02:50 PM
Jose's Avatar
Hi,
a Series 3 XJ-6 would have a Borg Warner 66, not a 12.
Old Apr 19, 2023 | 03:59 PM
Ken Cantor's Avatar
Just noting that starting from ‘77 through to ‘92 the automatic transmission used with the 12-cylinder engines was GM’s three-speed turbo-hydramatic 400 transmission…
Old Apr 19, 2023 | 06:28 PM
Jagboi64's Avatar
An easy spotting feature is the Model 65/66 is an aluminum case and the Model 12 is a cast iron case. The Model 12 was mainly used on V12 cars up to 1977, but 4.2 XJ6's did use it from 1970-73
The Borg Warner Model 65 was used from 1973-81, then the model 66 after that. The factory considered the Model 66 marginal for the 4.2 in European spec (205hp)
Old Mar 24, 2024 | 04:28 PM
Spud Maat's Avatar
as mentioned many posts back.
"or that the switchpack is worn and is not making contact when the switch is moved. this can be resolved by taking apart the switchpack, maybe inserting a small shim and then reassembling it. can take some playing around to get it right."
jagadam
Jul 12, 2022 03:55 AM
MMJ9992108Avenue
Dec 1, 2018 08:41 AM
razorboy
Jan 7, 2017 11:28 PM
mhannaoui
Nov 22, 2012 01:45 PM
Yaoi-Wiccan
XJ40 ( XJ81 )
May 6, 2012 09:15 AM
