? how to remove the entire distributor assembly on a 87 xj6
Old Aug 11, 2021 | 07:38 PM
retroren's Avatar
Default ? how to remove the entire distributor assembly on a 87 xj6
hi: i want to rotate the distributor assembly on my 87 xj6 so i can adjust the timing. i removed the pinch bolt and tried to twist the distributor but could not get it to budge at all. is there some other bolt that needs to be loosened? the ever-so-helpful service manual offers no useful instruction.
? how do i get the distributor to loosen so i can advance and/or retard the timing?
? for future reference, how do i go about removing the entire assembly? again i removed the pinch bolt with no apparent effect.
thanks, ren
Old Aug 12, 2021 | 09:47 AM
Fraser Mitchell's Avatar
Is your car an XJ6 Series 3, or the XJ6 that was introduced in the UK in 1986 ? The two engines are different in every way. As far as I know, all you need to loosen is the clamping bolt, but over time the distributor shaft may have seized itself into the housing. Have you tried a light tap with a hammer ? Don't overdo it, though !
stellar-warior
Oct 22, 2024 08:07 PM
Jacko5711
Jul 31, 2021 05:21 AM
Fingers13
Feb 6, 2021 12:10 PM
Exodus82
Jul 20, 2019 10:01 PM
adenshillito
Jun 22, 2015 06:44 AM
