how to remove rear seats?
Old Jul 30, 2014 | 08:23 PM
82jaguarxj6's Avatar
Default how to remove rear seats?
Running wires for Subwoofers to the trunk in my 82 xj6. I've got the wires all hidded, lower seat portion removed now I'm stuck. Can't get upper seats off and looks like there is nowhere to run cables through. I've got the 2 bottom bolts out bit feels like there is still some up top I can't feel or see
Old Jul 30, 2014 | 08:32 PM
icsamerica's Avatar
Just push the seat back straight up. There is plenty of room for wires on my series2, I'm not sure about the series 3,
Old Jul 31, 2014 | 02:00 AM
Jose's Avatar
1) first pull up / raise the front of the seat itself and remove it out of the car; The Seat itself is held in place by two Spring brackets at the front edges.
2) at the bottom corners of the seat's Back, you will see two "U" brackets screwed to the body, remove the screws;
3) push the seat's Back UPWARDS and then towards the front of the car to release it from two catch brackets located at the top shoulders of the Back.
this system goes back to the 1950's, all Jaguar Saloons (Sedans) are the same way.
Old Jul 31, 2014 | 02:14 PM
That did the trick, thanks guys! One more question. Where do you guys run wires through the firewall? Would rather not drill a hole in it, but if its a must I will
Old Jul 31, 2014 | 06:49 PM
icsamerica's Avatar
Passenger side, just to the left of the battery there is a blank that fills in where the steering columns would have been if it was a RHD car. It should have two vacuum lines. You can drill that, it's replaceable.
Better yet, if you need a high amperage 12V tap... right about the same place behind the air duct there is a lug on the inside of the car you can use. It will have a heavy rubber boot around it. lts un-fused, safety first...disconnect the battery when fiddling with this.
Old Jul 31, 2014 | 10:41 PM
Awesome thanks guys!
Jpav27
Jul 31, 2022 06:43 AM
davidladewig
Sep 3, 2015 06:32 PM
Joey T
Sep 3, 2015 05:31 PM
Dallas XK8
Sep 3, 2015 12:17 PM
dcvickers
Sep 2, 2015 06:14 PM
