I suspect the fuel pump 1986 VDP
Old Dec 27, 2021 | 03:09 PM
mikega's Avatar
Default I suspect the fuel pump 1986 VDP
This car was a quick starter and did run well before parked for about 10 months now with no start or run operation.
Recentry tried to start but failed, I got to know the injectors were blocked, took them to injectors machine shop to clean and open the nozzles.
Now, started well, engine runs well on idle, accelerated well on idle as well but when I put on drive gear and tried accelerate, the fire went off and engine died.
Could this be that the fuel pump is not strong enough to pump with higher pressure or what what's the cause?
Please help.
Old Dec 28, 2021 | 04:26 AM
mikega's Avatar
I have changed the fuel pump, cranks but takes longer to start and dies few seconds.
What could be the problem to look at please?
Old Dec 28, 2021 | 06:02 AM
mikega's Avatar
With further diagnosing, I disconnected the AFM sensor cable and afterwards, the car started once, shift gear to drive the car moved, shift reverse the car moved all by its own without acceleration.
I will replace the AFM to see the next result.
Old Dec 28, 2021 | 06:24 AM
I am going to assume? that the fuel filter was replaced, and the supply line to the front flushed with clean fuel prior to Injector re-install?
The fuel pump relay earth contacts inside the AFM, as in under that Black Plastic Cover, are a well known issue, thus shutting OFF the pump if they be grubby, or adjusted wrong.
Old Dec 28, 2021 | 06:27 AM
mikega's Avatar
I checked the fuel filter, there wasn't any debris not dirt in or from it.
How would I fix it solve the fuel pump relay earth inside the AFM?
Ixlr8-2
Mar 8, 2014 01:23 PM
RobertTheBloke
Feb 25, 2014 08:00 AM
mdtopless67
Dec 18, 2012 11:11 PM
Fixin Winston
Dec 11, 2012 01:51 PM
lrizzell
Nov 2, 2008 08:54 AM
