2002 VDP Fuel Pump
Old Oct 30, 2008 | 06:40 PM
lrizzell's Avatar
Default 2002 VDP Fuel Pump
My vehicle started with a rough idle. It then back fired, died and prompted me that engine stalled. I can't get it to restart. It cranks, tries to fire, but will not run and start. I removed the shrader valve on the injector rail to see if any fuel comes out, but none does. I checked the fuses in the trunk, switched out relays and still no luck. I do not hear the fuel pump when turning the key.
If the fuel pump is bad, can someone tell me how toreplace it. I know that the tank has to be removed, but I am not sure how to get to the pump. Also, do I need a special tool to remove it?
My car is at the bank, so if I can get a quick answer I would greatly appreciate it.
Old Nov 2, 2008 | 08:54 AM
oldmots's Avatar
Default RE: 2002 VDP Fuel Pump
From your description, the pump is bad or the harness is bad. Check the harness to the pump first and if it's okaythen pull the tank. Get a subscription to Alldata.com for all the details of the pump removal and replacement to be sure you don't miss anything.This job is a big one for a shadetree guy.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
Dicque
Sep 19, 2015 12:53 PM
Sprayall
Sep 3, 2015 07:49 PM
