Indicator and Hazzrd Issue
Old May 12, 2025 | 11:43 PM
adenshillito's Avatar
Default Indicator and Hazzrd Issue
tried two different flasher units, an old one and a new one. old one give a nasty buzzing bound, new one flashes the dash indicator lamps. no external indicator lights front or back. but i can open the plug that leads to the switches and power the external light directly on each side, i can also see that the stalk and the hza switch are both throwing signals correctly with a continuity test. and i can case the dash hazzrd lamp to come on, note this does not engaged with the hazzrd switch at moment only when powered via the wires directly. can someone remind me what the small four pin relay back and at the right there is for as it click and triggers when i run power to some of the pins of the plug to the stalker/haz switch.
stalky
stalky
that relay
that relay
benji808
Sep 13, 2023 06:23 PM
rgp
Oct 26, 2021 05:09 AM
JessN16
Jan 2, 2021 08:00 AM
SouthernGypsy
Oct 7, 2014 12:53 AM
Aviator-Olav
Apr 2, 2014 07:58 AM
