Insert in a Wire
Old Feb 25, 2024 | 03:47 AM
adenshillito's Avatar
Default Insert in a Wire
Just a curious little insert in a wire under the dash, red/orange wire on the lighting (mainly) plug a voltage regulator or restrictor. I thought it was the fog lamp wire at first but its not.
Old Feb 25, 2024 | 06:30 AM
Doug's Avatar
That's a diode; a one-way valve for electric current.
On Series III cars red/orange is part of the license lamp/marker lamp circuit. I suspect the same for a Series II. Not sure why a diode would be there. I suspect part of an alarm installation?
Old Feb 25, 2024 | 06:41 AM
iramphal's Avatar
What messy solder work! Hope those junctions were properly insulated.
Old Feb 26, 2024 | 03:05 AM
very globby eh, yes lots of insulation on them.
Old Feb 26, 2024 | 03:06 AM
yeah i cant figure what it is supposed to be directing power one way too. nothing obvious jumps out when tracing the leads.
Old Feb 26, 2024 | 03:03 PM
iramphal's Avatar
I believe the gauges supplied by the regulated 10V DC are the Oil pressure, Coolant Temperature and perhaps the Fuel tank gauge. The Voltmeter I think is from battery/Alternator supply. That would give you the 3 leads needed. I cannot be certain, as my S57 diagrams does not show any sign of a 10V regulator, but it makes sense to have a constant regulated voltage feeding those 3 particular gauges.
Old Feb 26, 2024 | 03:08 PM
iramphal's Avatar
Oh, hit the wrong thread - meant to send it to the 3 wire gauge thread!
Old Feb 26, 2024 | 05:55 PM
Jose's Avatar
the Turn signal bulb wires at the tachometer have a similar diode about 3 inches away from the bulb socket, wrapped in tape.
con244
Feb 20, 2026 06:23 PM
OwenEDC
Aug 22, 2023 07:35 PM
user 652867429824
Oct 16, 2015 12:32 AM
WaterDragon
Sep 2, 2013 04:41 PM
Vee
Jun 10, 2010 12:56 AM
