Neath the Steering Wheel
Old Feb 17, 2024 | 05:36 AM
adenshillito's Avatar
Default Neath the Steering Wheel
This coopery guy has the remnant of a bullet connector in the tunnel-like socket.... horn related I think. what should plug in, an earth or a positive of some sort. makes a nice image.
'coppery guy beneath the steern wheel
Old Feb 17, 2024 | 06:33 AM
Doug's Avatar
That's the grounding tab for the horn. The wire should be purple/black....but I'm only two sips into my first cuppa coffee so don't take that to the bank. If you find the wire and plug it in and the horns blows...well...you'll then know why it was unplugged
Old Feb 17, 2024 | 06:41 AM
I read that as "ground horn to a cup of hot coffee' which sounds like pretty solid advice I reckon.
Old Feb 17, 2024 | 09:10 AM
slofut's Avatar
Classic bit of Lucas engineering!
Old Feb 18, 2024 | 08:27 AM
yachtmanbuttson's Avatar
From personal experience, I can tell you that you should remove that contact (let's call it a brush), clean it and clean the rotating copper part (let's call that an armature). Then reassemble using di-electric grease. If not, that contact against the armature makes the most grating, annoying, grinding sound whenever turning the steering wheel. Which is about all the time.
Old Feb 24, 2024 | 04:19 AM
fairly sure from looking at some other pictures that an tidy earth with a large bullet head is inserted there.... just need to make one...
seems to be a black wire here.
Old Feb 25, 2024 | 01:01 AM
or ... wiat....
this one off the web....
Old Feb 27, 2024 | 09:20 AM
Aden, mine is sort of purple/pink.
SirJohn
Sep 30, 2023 10:17 AM
purpleporsche
Apr 10, 2020 05:41 PM
martymclendon
Feb 4, 2020 12:08 AM
sanchez
Feb 9, 2018 03:59 PM
dmericas
Nov 24, 2016 09:23 AM
