Intermittent stalling/Ignition Amplifier?
Old Aug 16, 2018 | 04:45 AM
DavidJC's Avatar
Default Intermittent stalling/Ignition Amplifier?
HELP!! My 86 XJ6 can run well for weeks and then unexpectedly it just just dies. The electrical system shuts down I cannot restart it. So far I have replaced both the pick up unit and coil. My best guess is that the issue has to do with something overheating or over stressed as it will restart easily after a cooling off period. Maybe a problem with the Ignition Amplifier?? What do you guys think?
Old Aug 16, 2018 | 06:58 AM
Jose's Avatar
if you already replaced the ignition amplifier and the coil, I would replace the ignition switch, which is suspect. Also the ignition Cap and rotor. But the symptom you describe sounds like a worn ignition switch.
Old Aug 16, 2018 | 07:13 AM
Doug's Avatar
Inside the amplifier is an ignition module, AC Delco part number D1906. This is what typically fails and they're known for "Fails hot, OK when cool" behavior. As guesses go, it's a fair bet.
As Jose mentioned the ignition switch is also a common culprit although, in my experience, they don't share the hot/cool pattern of failure.
Old Aug 16, 2018 | 07:26 AM
DavidJC's Avatar
His DD, Thanks for the quick reply. Do you happen to know the part number for the condenser that is included in the module? regards, dave
Old Aug 16, 2018 | 07:32 AM
Doug's Avatar
I don't, nor have I ever replaced one.
Over the years I've heard some say that "any condenser from a typical points-type ignition should work" but I really don't know
Old Aug 16, 2018 | 08:31 AM
Jose's Avatar
it is a GM module, available from GM.
you can find the part number in the Substitute Parts Listings, i will try to find the link to the page.
Old Aug 16, 2018 | 08:41 AM
Doug's Avatar
The module is GM part number 10482821 or 19180772
The AC Delco exchange part number is D1906 or D1918.
cel2620xl
16
Aug 8, 2018 07:26 AM
Rauly
May 8, 2017 11:22 AM
Jaguar2986
Mar 9, 2017 02:47 PM
jeremiahcalvin
Oct 18, 2011 04:04 PM
Tommahawk
Jun 19, 2010 09:28 PM
