Iridium spark plugs for V12 5.4 1991?
Old Apr 7, 2013 | 08:50 AM
Ilja Oblomow's Avatar
Cool Iridium spark plugs for V12 5.4 1991?
Hallo,
can someone here recommend any iridium or platinum spark plug (long life) alternative for the standard NKG BR7EFS plugs? Do you have some long time experience with them? Any issues with burned pistons?
Greetings from Berlin
Alex
Old Apr 7, 2013 | 09:09 AM
Doug's Avatar
As with oils and tires, opinions on spark plugs vary greatly.
FWIW, I never tried Iridiums on my V12 but I have on others cars, including my XJR. Never felt any difference in how the engine ran but the "long life" aspect seems true enough. Or, at least, I've never experienced or heard anything to the contrary.
Is there a particular problem you're having with spark plugs? Even the standard type should go at least 30k miles if all's well with the engine and ignition system. For most XJS drivers 30k miles would be several years of use.
Old Apr 7, 2013 | 09:45 AM
Doug's Avatar
It just dawned on me that you don't have an XJS, but, still........
Old Apr 7, 2013 | 02:59 PM
Hallo, yes, it is XJ12 , but 30 t miles will mean few years in my case, i do not think i will do more then 3000 miles per year :-). I just was thinking about it to spare a frequent changing, because i was thinking i have to change them every 5 t miles :-)
Thanks !
Old Apr 7, 2013 | 05:45 PM
Jtestrake's Avatar
5000 miles seems like a very short time span for changing plugs on any engine. As Doug said, 30K is a bit more normal.
Having said that, I usually change them out every two years or so. On my cars, that's only a few hundred miles. I change them to prevent the steel plugs from seizing to the AL Heads. A good anti-seize is probably all the insurance I need but I tend to get obsessive over this kind of thing.
So for me, it's every 30k miles or every two years, whichever comes first.
Old Apr 8, 2013 | 08:13 AM
peddlarbob's Avatar
I agree with John. I would never get close to 15,000 mile ayear on mine so every two years for me also. I always meticulouslycleaned/chased the threads and used anti seize when changing plugs.
On the original question, I never found a better plug to use on my seriesIII V-12 cars than the original one Jaguar specified.
cissdm
May 3, 2016 06:02 AM
BathoryFan
Sep 15, 2015 05:04 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
