Key Fob
Old Apr 15, 2018 | 01:59 AM
terryian's Avatar
Default Key Fob
Hi I have a 2003 xj6 3.0l petrol does anyone know how to pair a new keyfob with the car thanks in advance
Old Apr 15, 2018 | 04:15 PM
sov211's Avatar
You are in the wrong forum; this list is for the XJ up to 1987 for the 6 cylinder and 1992 for the V12. You want the "x300" list (x300 is the factory code for your car).
Old Apr 15, 2018 | 04:37 PM
Fraser Mitchell's Avatar
Actually, as this is a UK post, I suspect the car is an X350 series made of aluminium, like my car. If it is, then post in that forum. FWIW, I have no idea how to pair a new key fob, as the last time I bought one, the dealer did it.
Old Apr 16, 2018 | 10:26 AM
sov211's Avatar
Yes, you are right - 2003 XJ can be an X350 in the UK - thanks for catching that. Wrong forum in any case. But it is the dealer that must pair the key fob to the car's system.
Old Apr 16, 2018 | 01:02 PM
JagCad's Avatar
Key fobs. Interesting toys , My 94 Jeep has that feature. when it came to me, the fob did not. I found one on E bay. It came with a typed note as to how to sync it. The Jeep manual also had instructions. Not quite the same !!! Nevertheless, I got it to work. Then the batteries shut down. I found new ones. A bit pricey, but at the wrong place. I managed to split the case and it took an inordinate time to figure out hw to place the two coin like batteries and the spring. Got it. It worked. Achoo, it eats batteries. Set aside.....
Carl
yardbird
Dec 27, 2023 03:05 PM
daddylogan
Nov 27, 2016 07:18 PM
EscapedApe
Nov 25, 2016 06:18 PM
JimC64
Feb 13, 2014 07:35 PM
sjuraud
Aug 28, 2010 02:11 PM
