Leaking Rack & Pinion
Old Jun 4, 2013 | 06:57 AM
White Jaguar's Avatar
Default Leaking Rack & Pinion
I have a 1987 XJ6. The car is leaking power steering fluid on the rack and pinion area. I have pin-pointed the spot. It is leaking where the steering wheel shaft comes down and meets the rack and pinion area. There is a metal washer with a rubber seal. This is the area. My question is: What is the best or easiest way to change out this metal seal? I sorry I am not using the correct mechanical words.
Thanks in advance.
Old Jun 4, 2013 | 08:31 AM
icsamerica's Avatar
Default rack leak
The best way would be to remove the rack and replace it as a unit, some of the other seals may soon fail too. If you just want to change the rack tower seal you will have good luck finding just that seal on the internet. There are complete rack seal kits that cost about 1/3 of what a remanufactured rack costs and the labor ro remove and replace is the same so one could argue it would be prudent to replace the whole thing. Replacing the rack tower seal while the rack is in the car is very difficult and not recommend because debris could get in the rack while the tower was exposed.
Old Jun 22, 2013 | 11:45 PM
I just replaced my whole rack and pinion with the help of my teenage son. I promised my son that he could drive the Jaguar with me in the car. I want to thank icsamerica for his suggestion.
Old Jun 23, 2013 | 06:15 PM
86jag's Avatar
White jaguar: where did you end up purchasing your rebuilt steering rack? I keep debating weather to rebuild mine ( it is already out of the car, as well as the entire engine) or do I just rebuilt it myself. I know one of the seals is a pain to get correctly while the others are pretty good.
Old Jun 25, 2013 | 06:48 AM
I bought a rebuilt rack and pinion from Autozone.
rusty37
Apr 5, 2020 07:40 PM
thedugger1
Oct 16, 2015 10:06 PM
xk8don
Sep 22, 2015 07:41 AM
ahunt4
Sep 19, 2015 09:49 AM
sogood
Sep 15, 2015 07:35 AM
