left headlight no light right headlight fine
Old May 3, 2015 | 10:02 AM
Anfield Dreaming's Avatar
Default left headlight no light right headlight fine
I have switched the lamps and fit a new lamp the left lamp still won't function are there independant fuses for each circuit?
(Lets get her running for summer!)
Old May 3, 2015 | 10:47 AM
Doug's Avatar
Yes, four fuses....er....on the Series III cars, at least. What car do you have? Anyhow, clean the fuse end caps and the fuse box clips. Ands check the headlight ground wires which are on either side of the sheet metal framework around the radiator
cheers
Old May 3, 2015 | 12:45 PM
It's a 77 series 2 where would I find the fuses?
Thanks!
Old May 4, 2015 | 07:47 AM
Found the fuse for the headlights one blown replaced no change suspect it's a deeper fault
Attached Thumbnails left headlight no light right headlight fine-forumrunner_20150504_133923.png
Old May 4, 2015 | 07:53 AM
Doug's Avatar
Did you check the ground/earth?
Do you have a test light or test meter to do some basic checks?
Old May 4, 2015 | 09:50 AM
Hello just ordered a multimeter (gave all my tools back when I changed job) will update on tuesday cheers
Old May 4, 2015 | 11:16 AM
JagCad's Avatar
Suggestion:
Make your self a test light. From simple to elegant.
Any small 12 v lamp socket and bulb. A black wire and a red wire. Solder and soldering gun. The probes can be most anything, from a pair o skinny nails to pices of clothes hanger wire.
Or, no socket, only a bulb? No problem. Solder the red to the contact tip of a bare bulb. solder the black to the brass body of the bulb.
But, in your case, the blown fuse is a strong clue. Over load somewhere. Fried a wire or connector til it is open?
A visual tracking might find that open.
Carl
Old May 4, 2015 | 11:30 AM
JagCad's Avatar
And, ditto to Doug's find and clean the grounds.
Old May 4, 2015 | 11:44 AM
Great news after giving up it,I decided to spend a bit of time cleaning all the spade connectors on the electrics and when o went to finish up I thought I would try one more time and they LIT UP!!! changed them over to a halogen set up that I purchased a couple of weeks ago and now we have LIGHTS! Thanks for the hell and patience. I still can't get my dash lights working but hey ho.
Old May 4, 2015 | 12:34 PM
JagCad's Avatar
Great, it works almost every time1
I call it Jaguar Electric Mantra. clean, tighten and in some cases lube, connectors.
Or, a term, I am accused of coining, "electrickery.
But, make that test light. I grew up on them for lesser critters. Pre meter days for me.
I did make a crude VM. An NOS meter intended for an IHC truck. Made up some leads and probes. Still ion my electrics box. although, I now have analog and digital VOM's, somewhat recently joined by an inductance meter.
As, I am far from an electrical genius, I keep each in its original box replete with the use instructions.
Carl
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
