Limited slip oil in a standard Diff.
Old Nov 5, 2025 | 03:18 PM
iramphal's Avatar
Default Limited slip oil in a standard Diff.
Guidense please. Can I use a good quality LSD oil in a Non-LSD Diff? I believe all Soverign models came witht a LSD, But I want to have a suitable oil for the shop tht will drain and replase whatever is in there. I know about the Diff tags, but until it's on the lift and I give them the oil to use, I won't know what I have in there now. And yes, I know to just take a peek at the diff tags., but I don't have a lift and I'm not planing to crawl under to check. Yeah, Lazy!
Old Nov 5, 2025 | 06:05 PM
Doug's Avatar
I've done so before with no problems, FWIW
Old Nov 5, 2025 | 07:38 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
LSD gear lube has a friction additive that allows the clutches of the limited-slip to slide or move against each other while being under normal pressure. Without that modifier the clutches want to stick to each other and will cause a jerking or popping sound when going around a corner. The modifier does not affect the quality of the oil and its ability to lubricate the gears. LSD oil won't hurt a non-LSD diffy, just don't go the other way. This is the TMI version of Doug's answer.
Dave
Old Nov 5, 2025 | 09:50 PM
Jagboi64's Avatar
It will make no difference. The LSD additive in a regular diff will perform no function and won't affect the operation.
peterj1974
XJ40 ( XJ81 )
Feb 1, 2025 09:02 AM
Givoo
Aug 19, 2023 05:51 PM
Jeff Morris
Jul 25, 2023 11:40 AM
Ant Buck
Jul 3, 2023 08:59 PM
2004XJ8
May 29, 2020 02:28 PM
