Looking for wiring diagram of a 1970 XJ6 series 1
Old May 19, 2022 | 06:58 AM
Bertrand44117's Avatar
Default Looking for wiring diagram of a 1970 XJ6 series 1
Hi everyone,
I am in the final stage to crank my 1970 XJ6 series 1, however I am facing an ignition issue, I have changed pretty much everything on the ignition line (HT Coil, Ballast resistor, Condensator, points, spark plugs, HT leads) but I am not getting any spark. I have run mutiple tests to check voltage, continuity and so on, and I have noticed weird readings as follow:
Contact Ignition on:
Coil Positive to ground 5.98V
Coil Negative to ground 0.7V
Coil Positive to negative 5.45V
Something's wrong somewhere and that's I am chasing for advice(s) as well as a correct wiring Diagram !
Bertrand
Old May 19, 2022 | 07:02 AM
Coventry Foundation's Avatar
Bertrand we have the charts but depending on the original market the car was sold in there are differences. You also do not say which engine your car is fitted with. 4.2L or ???
Old May 29, 2022 | 03:31 AM
Hi,
Sorry for the late answer. My XJ is 1970 XJ 4.2litre. Attached is the VIN plate
Bertrand
SableXJ6C
Mar 18, 2019 07:19 AM
osyris
May 26, 2017 08:32 PM
Daimler
Jun 14, 2013 06:05 PM
wnlewis
May 11, 2009 06:38 PM
love1u0
Oct 11, 2008 09:24 PM
