Low Voltage to AC Clutch
Old Mar 13, 2018 | 05:48 PM
sdduke's Avatar
Default Low Voltage to AC Clutch
I have a 1984 XJ6, and I am trying to get the AC back in service.
The problem is that I am getting only 3 or so volts at the compressor clutch line (green brown line).
I measure the same voltage upstream of the Ranco Tstat, and at the brown yellow wire feeding the fan relays.
I have bypassed the water temperature switch too.
Any ideas as to where I am losing 9 volts?
David in Atlanta
Old Mar 13, 2018 | 06:49 PM
NBCat's Avatar
Check the loom and connections for corrosion. With the power disconnected, check the circuit for high resistance.
heflirob
Sep 26, 2016 04:50 PM
MannyJag
Apr 18, 2016 10:17 PM
Spillwaybob
Aug 28, 2013 06:31 AM
caimano
Apr 26, 2012 11:09 AM
svldvc
Feb 12, 2011 01:46 AM
