Mechanic found various leaks, are there temporary fixes?
Old Feb 4, 2013 | 05:26 PM
Socal's Avatar
Default Mechanic found various leaks, are there temporary fixes?
After taking my 1985 XJ6 Series III for an inspection, my mechanic found a few leaks.
Oil Cooler hoses,Cam Cover Gaskets and Transmission cooler hoses. The fix for all three will require about 1 month before I am able to afford. Can anyone recommend a temporary fix until I can get repaired?
Any help would be appreciated!
Old Feb 4, 2013 | 06:56 PM
Doug's Avatar
Can't think of any temporary fixes.
One tip, though. Have your mechanic clean the breather screen and pipe. Chances are it's clogged.....which will increase crankcase pressure....which in turn can make engine oil leaks (pan gasket, rear/front main seal, cam covers) worse.
Old Feb 4, 2013 | 07:40 PM
Socal's Avatar
Great info Doug, Thank you so much!
SD96XJ6L
Jan 12, 2022 04:30 AM
allenman85
May 10, 2021 03:11 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
Russ Graber
Feb 23, 2019 11:59 AM
tberg
Sep 7, 2015 07:32 AM
